The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
New JS function for x-counters handling
Using legacy coding, it's possible to pick the x-counters from another stream.
For example,
formatting.evaluateShowString('="@vData:Main"x(5)x(5)');
will transfer into cuurent stream x(5) counter the value of 'Data:Main' stream's x-counter x(5) at the begging of the current page.
Even if it's probably already possible using display, I think that a core fonction would be interesting, looking like this:
formatting.getCounters(streamName, counters, relativePage)
where:
  • streamName : name of the stream to import counter(s) from. If does not exist, do nothing
  • counters: un number / array of number. if null => import all. If number: import this counter. If array of numbers: import the corresponding counters, if empty array just do nothing !
  • relativePage, default : 0 : pick counters value from relative page, if 0 : current.
 For example, formatting.getCounters("strm0",10,1) would be similar to this:
giving <?show ="@vstrm0"1x(10)x(10)>.
4 Comments
GarethOakes
Jacques, I think you could already implement your own getCounters() function using fdStreamPos counters/stringCounters. Besides the convenience of what you suggest, is there a novel concept here that I'm missing?
jtripoz
3-Visitor
Yes of course, I could implement it quite easily but I just think that a core function would be useful for everyone !
SimonTaylor
11-Garnet
Status changed to: Under Consideration
SimonTaylor
11-Garnet
Status changed to: No Plans to Implement
