Request for Arbortext API for selecting parts of text from different elements
This is a request from a PTC partner.
They need to programatically select a section of text that might extend over multiple XML elements.  If they use CharRightExtend, it will always require the text to be in a balanced selection.  This is true even f they set the option balancedselections=off.
The find() api has an option to ignore balanced selections, but find() will not work in their script the way CharRightExtend does.
2 Comments
GarethOakes
Yes, good idea. We have had some issues with clients who are using Arbortext almost like a word processor and need character-by-character change tracking across elements. In those cases our custom code also needs to be able to work on a character-by-character basis irrespective of the XML element structures.
plutsky
Status changed to: Current Functionality
It turns out that this can be done today.  If you look at the code for the alias CharRightExtend in commands.acl:
alias CharRightExtend {
if (columnview_cell_focus() > 0) {
beep;
} else {
unit_caret_move($h::tblRight);
You can turn this into a function and turn off the balancedselections setting inside the function like this:
function CharRightExtend2() {
local balspecorig=option("balancedselections")
set balancedselections=off
beep;
} else {
set balancedselections=$balspecorig;
