This is implemented latest with Arbortext Version 6.1M020!
Hello!
We'd like to raise the following product idea by demonstrating the current problem with a sample:
When you open
[Arbortext Editor Installpath]\samples\isoview\graphic_links.xml
in Arbortext Editor and publish this file to PDF (PE with APP engine), some of the graphics are rendered properly.
However, the acani.iso (with @id="blower-for-animation") is rendered very poorly. It seems that this file is rasterized and that a screenresolution (at max.) is used for that.
With that, we cannot create high-quality PDFs.
Our product idea is, that the intelligent graphics are converted in vectors or rasterized at least to a good printing-solution (such as 300dpi for the resulting image-size).
A default-resolution and an option to change that would be very appreciated for publishing.
This option should be available for all publishing-formats available.
Thank you,
your Windchill Team @ DATACOPY
