Hello!
Although this is s.th. for the xml power-user, it is nevertheless heavily requested from this user group:
It should be possible to do some searching in Editor with XPath-Expressions and these XPath-Expressions should consider the latest XPath standards.
Thank you very much,
your WindchillTeam@DATACOPY
Note for PTC: Legacy E8223807
