Styler region positions relative to custom coordinate system
It would be very helpful if it was possible to define a region's position ("X position" and "Y position" properties of a page region) relative to a custom point rather than relative to the out of the box points (page/marging edges or center).
Use case: in a page there are regions and nested regions: positions of nested regions are defined relative to some fixed point within the parent region.
Alessio
5 Comments
SimonTaylor
11-Garnet
Hi Alessio
Could you do something with the named dimensions thing? For example, set a named dimension to the x-position of the parent region and then use that for the child regions?
Perhaps the enhancement would be to allow named dimensions to be used with some mathematics such as x-pos + 5mm...
Simon
Alessio
Simon,
are you referring to what Styler called "Sizes"?
I can use a size as the Position X for a region, but cannot perform arithmetic with them.
This is what we have today:
X position: "From left margin" - MySizeX
This is what I'm looking for:
X position: "From MySizeX" - MyRelativeSize
SimonTaylor
11-Garnet
I understand. I was just wondering whether perform arithmetic with the Sizes might be a useful feature, which could be used more extensively than relative region locations...
What do you think?
Simon
Alessio
As far as this use case (nested regions), it would be nice to have another region as the reference, just like we have page and margin.
Example:
Region 1: Region reference point = Top left; X position = From left margin, 5mm
Region 11: Region reference point: Center; X position = From left "Region 1", 10mm
This would translate to:
Region 1: the top left corner of "Region 1" is 5mm away (on the right) from the left margin
Region 11: the center of "Region 11" is 10mm away (on the right) from the left border of "Region 1"
As far as being able to perform arithmetic with sizes, this looks a lower-level approach.
It might be more complete (might cover more use cases), but less usable for the specific use case above.
I know you're asking if I can think about other use cases that might be covered by your suggested approach.
One slightly different use case might be "region groups": regions in a group move together as the group is moved. This is equivalent to defining a region for a group and all other regions relative to the group.
The mother of all use cases would probably be creating a flexible layout that would adjust the size and position of a region (at least those marked as "flexible") as other parameters change.
Alessio
olivierlp
Community Manager
Status changed to: Archived
