The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Warning Pop-up about a missing valid JRE when installing Arbortext Publishing Engine
Since 7.1 M050, the JRE installation is not embed anymore in APE installer.
Then, prior to installing APE, we need to manually install a valid JRE APE will find and use.
Could we add a warning pop-up in the APE installer first steps (before executing the installation) if no valid JRE is found?
It would be very helpful and probably avoid  quite a lot of support cases open as this is a complete new behaviour for previous users of APE.
It could be nice to get this pop-up just as a warning as I suspect some users could already be aware of this JRE installation need, but would want to install APE first then the JRE later.
2 Comments
plutsky
Status changed to: Under Consideration
Yes, it would be helpful to provide a warning in the installer.
plutsky
Status changed to: Delivered
