Currently in the Arbortext print engine, PDF bookmarks can be controlled by identifying elements in the DCF as titles.
I would like to be able to generate PDF comments in a similar manner.
Having the ability to generate in-text comments would add another level of usability to our PDF products.
Ideally, I could identify these as "Tips" or some other type of comment (but that's probably a limitation of the PDF spec).
And/or, I would like to be able to have bubble definitions show up for words/phrases.
Thanks for your consideration,
Steve Groth
