Hello!
The XPath-Queries in Styler should always support the current standard of XPath, which is - at the moment - 2.0. XPath3 can also be viewed at the horizon.
The supported X* standards should be integrated in the product in a good time-span, after the version becomes a standard. So focusing on the implementation of XPath2 is way overdue!
Thank you very much,
your WindchillTeam@DATACOPY
Note for PTC: Legacy E8223757
