When doing a mass update in a line sheet – after hitting save – the screen doesn’t change or call out that changes have been completed. The users have to hit “cancel” to return to the original view for the line sheet. If there was a way to edit the button names to make more sense for the users, that would be great. Having a button named cancel, makes assumptions that you will cancel the information that was just updated.
Example for this button: change from "CANCEL" to "COMPLETE" so the user can use that as a validation that there changes are completed. or RETURN so the user can return back to the line sheet.
