When you use native idr files in editor it shows everything in the file. When you use cgms they crop all the information around the hatched box. Modify editor to have idr files operate like cgms and crop to the vdc extent. This will make editor only show what it on the hatched box in Isodraw.
Why are there no plans to implement Patti? It would allow native idr files to be used in editor with out showing everything automatically. It is already a feature that is done with CGMS when you modify the isoconvert file in the editor install folder.
I appreciate that this would be good to have. At this point I can't schedule the enhancement to have the idr viewer crop what is viewed in Arbortext Editor.
Patti
