When you use Arbortext Editor, you can add images stored in windchill as Graphic Dynamic Document. This kind of object is a subtype of EPMDocument. You can create a GDD using a command, in File menu, that upload only one file at a time. If you have 1.000 images to upload, it takes a lot of time because there isn't a loader.
Is it possible to create a loader also for Dynamic Documents?
