need for 64bit Isodraw7.3 application
대용량 어셈블리를 가지고 CAD Process 작업을 하기 위하여 64bit용 Isodraw7.3 어플리케이션이 필요하다.
32bit Isodraw7.3에서 메모리 한계로 인하여 대용량 어셈블리를 열기 작업이 불가능하다.
6 Comments
Pushpinder_Toor
Can you please translate this to English and I can see if we can respond to your inquiry. Thank you!
thendricks
3-Visitor
By no means perfect, but a quick Google translate comes out with...
'Isodraw7.3 application has a large assembly is required for 64bit to the CAD Process jobs.
Opening a large assembly operation is not possible due to memory limitations in the 32bit Isodraw7.3.'
Looks like a large assembly is not importing into IsoDraw and the theory is that a 64bit version would do better than 32. I know on larger assemblies that IsoDraw can be a bit clunky, but usually it just takes a while (10-15 minutes for a few on our side) but it usually comes down to available memory on the machine as well as other software packages open. For instance, I wouldn't suggest having the assembly open and Creo and then at the same time try to open in IsoDraw.
VladimirN
24-Ruby I
또한 생성 된 아이디어에 대한 투표 할 수 있습니다.
JeffreyCoon
9-Granite
We understands that today IsoDraw has a limitation when handling large assemblies due to its 32bit nature. The current work around for this is to use Creo Illustrate to create the base image and save that out as an IsoDraw native file to be completed in IsoDraw.
Our long term goal to fix this is we are adding 2D illustration tools to Creo Illustrate. This is an ongoing effort and will be rolled out over the next 18+ months.
Creo Illustrate is already a 64bit tool with better 3D tools. So by adding IsoDraw type 2D support, we intend to bring together the best that each tool has to offer. IsoDraw is not going away anytime soon and customers using IsoDraw will get special consideration as we bring these two tools together.
Google translate:
우리는 오늘 IsoDraw를이 인해 32 비트 자연에 대형 어셈블리를 처리 한계가 있음을 알고 있습니다. 이것에 대한 주변의 현재 작업은 지난번는 기본 이미지를 생성하고 IsoDraw를 완료 할 IsoDraw를 기본 파일로 그를 저장 설명하십시오 사용하는 것입니다.
이 문제를 해결하기 위해 우리의 장기 목표는 우리가 설명하십시오 지난번에 2D 그림 도구를 추가하는 것입니다. 이것은 지속적으로 노력하고, 다음 18 세 이상 개월에 걸쳐 출시 될 예정.
지난번는 설명하십시오 이미 더 나은 3D 도구를 사용하여 64 비트 도구입니다. 그래서 IsoDraw를 형 2D 지원을 추가하여, 우리는 각 도구가 제공하는 최고의 함께 가지고 계획입니다. IsoDraw를 조만간 멀리 가서 우리가이 두 가지 도구를 가지고 같은 특별한 고려를 얻을 것이다 IsoDraw를를 사용하는 고객되지 않습니다.
khoward
7-Bedrock
Jeff are you saying IsoDraw is on its way out to be replaced by Creo? If so will there be an upgrade path for current IsoDraw users?
Keith
olivierlp
Community Manager
Status changed to: Archived
