Figure numbers in my Appendix are wrong
rlaborde
I am using Arbortext Editor with Styler V7.0 M070 with DTD 38784STS-BV9a. Somehow, the numbering of the figures in my Appendix got out of whack. In my chapter 8 I have 35 figures and they are numbered 1-35. But in my appendix the first figure shows as A-36. I need it to be A-1. Any help is appreciated.
4 REPLIES 4
Are you using the appendix tag to start your appendix?
Did you use a chapter tag to start your appendix?
Did you update/refresh your SGML file?
The appendix tag is placed between the <rear> and <ending of the document> tags.
rlaborde
(To:ML_9713336)
Yes to appendix tag following rear and no chapter tag. Not sure what you mean by "update/refresh SGML"
Use this tag in your icon bar.
It is the document icon with the lightning bolt in your toolbar. Sorry but the picture of the graphic did not load properly.
