5.2 JVM
pcarey
5.2 JVM
Can anyone tell me what version of the JVM Epic Editor 5.2 ships with?
PETE
6 REPLIES 6
If you have a copy, just bring up the java console:
Java VM Version 1.5.0_04-b05 -- Sun Microsystems Inc.
John Dreystadt
Software Development Director
Arbortext - PTC
734-327-6079
pcarey
(To:pcarey)
Thanks: I don't have 5.2 so I couldn't test this myself.
Does anyone have any experience using Java 1.5 with Epic 5.1 (using set
javavmpath)?
Any problems in doing this?
I think this has been discussed on this list in the past, but I don't have
access to the archives.
--PETE
| | "Dreystadt, John"|
| | <jdreystadt@ptc.c|<br/>| | om> |
| | 03/16/2006 10:54 |
| | AM |
| | Please respond to|
| | adepters |
So, uh, has anyone had success bringing up the Java console?
I just installed 5.2 in a separate directory from 5.1 and receive this message when attempting to do anything with Java (including attempts to bring up the console):
[A30156] Cannot register Java native calls for the AOM Node interface.
Is it possible that a prior installation of both the JDK and JRE for 1.5.0_04 could be getting in the way?
You know how it is; there must be at least 5 different versions of Java this-or-that in under a year of using this machine.
Jason
there
must be aom.jar either in your APTCUSTOM/classes or in your classpath somewhere.
Remove it and you will be able to bring up java console.
size=2>
class=656221523-24032006>
Thanks! That did the trick.
Dave Maung <dave.maung@ceb.ucop.edu>
03/24/2006 04:15 PM
Please respond to
<adepters@arbortext.com>
To
"adepters@arbortext.com" <adepters@arbortext.com>,
Adepters@maillist.arbortext.com
cc
Subject
See response to specific question below.
javavmpath)?
We've not comes across any problems using Java VM Version 1.5.0_04-b05
-- Sun Microsystems Inc.with Epic 5.1
--PETE
| | "Dreystadt, John"|
| | 03/16/2006 10:54 |
| | AM |
| | Please respond to|
| | adepters |
