5.4 licese update [was color of SGML file entities not an option in Editor 5.4]
ptc-953343
At 10:49 AM 7/10/2009, you wrote:
>Hi Dan--
>I suspect you're probably right about the new directory structure being
>the issue. I haven't tried it, but I think if you copy the *.lic files
>from the old Arbortext folder into the new PTC folder, the new version
>would pick up those licenses and use them.
I wasn't sure which files to copy and when it didn't do this
automatically, I went for the new license key. The other odd thing
was it looked like it had a different server code when I looked at
the text of the existing license file. I'll try this on another
machine and see what happens.
..dan
>--Clay
>-----Original Message-----
>From: Dan Vint [
>license.
>..dan
>At 10:07 AM 7/10/2009, you wrote:
> >Dan,
> >According the the install guide for 5.4, chapter 6, Upgrading
> >Licenses, "There is no need to upgrade your licenses, since
> >previously issued licensing keys for (Arbortext Editor) will
> >continue to work..." Are you saying that you ha...
You can go to the Arbortext support part of the PTC website and look at
your license information. It might help you figure this out.
That's what I did. I returned the old license and entered the new
code. All is working, just not like previous updates.
..dan
I meant that they should have a history of your server codes and license
keys, so you could figure out if your server code really did change.
The only reason I mentioned it was because you said that "..it looked
like it had a different server code...". I thought that maybe you
weren't sure.
