6.1 Publishing Engine - licensing question
JasonBuss
7-Bedrock
Ok, so I'm needing to request a Flex license for one of our PE installations (testing 6.1 from 5.4).
Does the PE server license need to be node-locked or floating? Reading through the knowledge base, I am not getting a definitive "this/not this" feel for what I need to use.
Also, when requesting the Flex license, does the PTC Host ID/Host Name need to be the ID and name of the license server, or the server PE is installed on?
Jason A. Buss
Sr. Engineering Procedures Analyst
Technical Publications
Textron Aviation
316.517.7749 PHONE
jabuss@txtav.com
[cid:image001.png@01CFFDBC.5029CF30]
ptoor
(To:JasonBuss)
Hi Jason-
PE can be licensed either way – locked or concurrent.
The PE license is tied to the license server; the software can be on a different server and point to the license server.
Pushpinder Toor, SLM Solution Manager
