delete_buffer -all;
clears Arbortext paste buffers -- but not apparently the Windows clipboard--so don't know if this helps.
- Lou Argyres
CEB / Continuing Education of the Bar | ceb.com
In Reply to Paul Nagai:
Whacky. But I needed to do this an stumbled on a way how to do it. Maybe
it's useful to someone else.
# The following may have dependencies on sgmlselection, selectionsvc,
pastepreserve,
# and/or any other settings related to buffers, copying, pasting, etc.
# Create a temporary buffer and make it current.
set paste=junk
# write to that buffer. You could select and copy something if
# wherever you that is easy. Or you can just write a line of
# throw-away text to the buffer. Type "help insert_buffer" for
# a complete description of the syntax of this command.
insert_buffer("any string of text",0,"junk")
# Set the default buffer back to current.
set paste=default
I had to tell you now because it's Friday and my weekend will permanently
purge MY buffer and I won't remember I wanted to tell you come Monday ...
Paul Nagai
