ADEPT & Whitespace -Reply
Highlighted
Newbie
I have seen with Adept 5.4.1W that you can get multiple whitespace if
you are not careful in cutting and pasting. Adept seems to check to see
if the character next to the insertion point is whitespace and if so, does
not add another. But it does not scan the document during deleting or
backspacing to keep multiple white spaces from accumulating.
Jason Mohyla
Sun Technicom
Valley Forge Group
>>> 05/12/98 07:22am >>>
> From Michael Pomponio Mon May 11
06:39:14 1998
...[snip]
> We are assuming that all whitespace in 'element context' is removed,
and
> all whitespace inside PCDATA is turned into a single space. [Have we
> assumed wrong?]
The behaviour I've witnessed with ADEPT (5.4.1 through V7) is that
when you
are editting, you cannot enter multiple spaces in series in a PCDATA
area
unless you are working in an element that the FOSI has defined to have
"as-is quadding". However, if your SGML data was created outside of
ADEPT
and within the PCDATA areas there are places with multiple spaces in
series,
ADEPT preserves them and does not collapse them into a single space.
Curtis Jones
Lucent Technologies
cjj@lucent.com
Tags (2)
