AW: AW: AW: Word to XML
kaestle
Hy Lynn,
the problem that Word 2003 can't open (as is tried) depends on the doctype
header.
you normally have something like this:
"\\RS\DocTypes\RS\RS.dtd">
<rs>
</rs>
if you take notepad or something similar an change to:
<rs>
</rs>
Word should be able to open it.
"Arbortext doesn't have to worry about Macro$carf taking their
business from them at this time."
I agree, and i think it's something like "stocks to watch for"
best regards
Roland
> Roland,
> Ich habe Word 2003 Pro.
> When I tried to open one of my XML files that Epic has no problem with
> using my DTD, it didn't like the file. As I said, as I was traveling, I
> haven't had time to really sit down and "play" (spiel) with it and see
> what
> it will or will not do. I just tried another file very quickly and I can
> get tag information, but if I try to associate it with anything (i.e. a
> DTD, the only thing that I can enter are schema (XSD) or other XML.
This will take some getting used to. Arbortext doesn't have to
worry about
Macro$carf taking their business from them at this time.
> Danke fur die Antwort.
> Lynn
lynn
(To:kaestle)
Roland,
Actually, the one file it didn't like only had a PUBLIC identifier with no
SYSTEM information. Or the DTD wasn't listed as in your example. I haven't
tried removing the DOCTYPE header (I'm an old SGML type and DOCTYPE headers
are needed).
Even with a file opened, Word 03 still didn't like my DTD. Like I said just
need time to experiment.
As for stocks to watch. Now that is scary. Arbortext, a division of
Macro$carf. Or worse. Macro$carf Epic. Enough to scare me.
Lynn
