AW: problems with Forced Column Break
kaestle
Hi Tamara,
may it be possible that you try to force a coumn break at a place where the
FOSI defines that the elements have to keep together?
I tried as a sample the ATI MIL-M-38784C reference document
(Datei-Neu:Beispiel ...) and tried to insert some forced column and page
breaks.
In some cases you will get an columns(page) overflow, in some case the
columns break will not appear in the preview (depending on keeps and breaks)
in some cases it will work like expected.
hope i could point into the right direction
Salve!
Roland
> -----Ursprüngliche Nachricht-----
Hallo!
I checked the keeps befor and I´m sure I have no keep inside.
The problem appears with pictures which float to the top of the columns.
If there is a picture and a column break befor Epic do stupid things. It
seems to be unpossible to float the pictur on the top of a new column.
Maybe you have an idea whats to do that Epic first make the break and than
show the picture on the top of the new column.
Best regards Tamara
