One thing to keep in mind when you use a command from the editmenu.cf (or
any other ACL file for that matter). Is if you test if from the command
line, the syntax may be slightly different than what you see in the ACL.
This is the nature of ACL. So the inverse also holds. Once you have the
syntax working from the command line, it may not work in your ACL (or
keymapping).
What might work equally as well as a keyboard mapping is to set a popup
for use with a right mouse click. See help 298 on how to add to the popup
menu. I personally like the keyboard so I don't have to keep moving from
the keyboard to the mouse, but if I am on the mouse, then the right click
is helpful.
Lynn
