Accessing Source XML in Frameset (e.g. publish date)
JamesCLS
This is for "For Web" publishing (see screenshot below).
I started with the default frameset found in C:\Program Files\PTC\Arbortext Editor\framesets\default (as pictured below).
As a test, I just threw in a "<xsl:value-of select='//date'/>" which did not work (pictured below).
Does anyone know how I can pass data from the source XML file to the frameset?
I know I can retrieve the publish date on the client side using JavaScript, but I would like to limit the client side processing as much as possible.
-James
0 REPLIES 0
