Activation Free COM Registration
songmyos
For all you .NET Epic Developers, refer to this article to deploy your
COM DLL without having to register it:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dndotne
t/html/rfanetwalk.asp
Follow the article EXACTLY. Now, does anyone here know how to easily
compile VB code located in numerous files into a single DLL.
Unfortunately, you'll have to compile your code with the win32resource
switch using VBC for all this to work. I tried to embed the compiled
manifest file for the DLL within the IDE, but this didn't work. Aloha.
-Gerald.
I'm not sure if I understand your question or not, but you might try the .Net task of Ant if your already familiar with it or just NAnt if not.
http://ant.apache.org
http://nant.sourceforge.net
You should be able to do an xslt from the .vbproj file to the build file.
--tim
