I would like to edit the default line styles to add more line styles that are available to all graphics. Currently I have to create the line styles with each new drawing, is there a way to edit the line styles to add more styles?
I would also like to add different sizes and angles of the arrowheads available. I have not seen any information in any of the users manuals.
Keith
See your other post about customizing. The preference file also allows you to do this.
A note that I learned the hard way. The arrowheads you refer to can be called in the preference file. Note, however, that the arrowheads are preset. There are a number available by default, but I haven't found a way to make them smaller if so desired.
