I have attributes called desktop, cycle, show etc., in my atict tags. These are currently fed into the XML file through an external transform program. When I try to open the xml file in ArborText after running this transform it shows the following error:
*** Error on line 22 in file Q:\NextGen_3A\Cycle_1\01 For XPP Composition\01 Clean\10-1111-20.xml:
[A11053] Unrecognized attribute "desktop" for tag "atict:add"
[A11053] Unrecognized attribute "cycle" for tag "atict:add"
Since these attributes are not defined in atict it throws up the error. Can someone advise which file should I modify to add these attributes.
Karthik
I tried to add my attributes into the atitag file but it does not work. However on the atitag.cf file there are note on how to add the new element but all I need is just add attributes. I did not change attr1 to attr9 rather I created new attributes. I am still getting the error.
I have attached what original atitag.cf and the one that I modified. If you can guide me it would be helpful.
Karthik
Thanks James,
I did the same thing and added custom attributes to my atict tag and I am getting unrecoginzed tag error in AT. Upload the screenshot.
Karthik
