Hello all.
I created a book map with two chapters whick contain 4 or more topics in each and it is going to be published in PDF format.
Then, to save the number of page, I am trying to show two columns in one page and each topic should start from the top of the page.
However, Arbortext Styler does not have such function in its UI.
I am wondering if this can be achieved with some souce editting.
Do you know any source edit that works for this problem?
Thank you for your time.
Best wishes,
Tomomi
Check the breaks tab. I don't have Styler in front of me right now but you what you want is to set a "break before" of type "column", otherwise known as a column break. Set that for your topic (or possibly topic/title) and you should be away.
