Security Alert Log4j Security Vulnerability. Click here to know more.
Antwort: FOSI - put an image in background
ebenton
If you put a graphic in the header it will go on the page before the text and graphics. Unfortunately, unless your graphics have transparent white space, any graphics on a page will have their white space obstruct the background. If you put the background in the footer, it will go on the page after the text, but unless the background is transparent, it will obstruct all of the text and graphics on the page.
Unless all of your graphics are already transparent, it is probably easier to put the background in the footer and make your background transparent, tather than change all of your existing graphics.
If you are using Adobe Acrobat 6 or 7, you can create a PDF file of your background image and use it as a watermark or background on all pages. You can even rotate it. This only works with Acrobat 6 or 7.
Hy,
funny things may happen :-), but this solution works fine for me.
I have
where "back" is an Entity defining a small gray image.
This image is stretched in a way that it appears as background for my
flowtext area. Inside the flowtext area I have text as well as images, no
problems with transparency or unwanted page breaks.
Perhaps it depends on the Epic version you use or the graphic format??
Yvonne
"Benton, Ed L"
<ed.l.benton@lmco <br="/> .com> An
adepters@arbortext.com
30/08/2005 12:22 Kopie
Thema
Bitte antworten RE: Antwort: FOSI - put an image
an in background
<adepters@arborte <br="/> xt.com>
How to code the insertion of the pdf file like an image?
David
-----Message d'origine-----
De : Benton, Ed L
Envoyé : mardi 30 août 2005 12:25
À : adepters@arbortext.com
Objet : RE: RE : Antwort: FOSI - put an image in background
If you have the "Acrobat Distiller" printer or, as in the case of Acrobat 6 or 7, the "Adobe PDF" printer, just open your image in whatever viewing/editing program you use, and print it, using "Adobe PDF" (or Acrobat Distiller) as your printer. This will create a PDF file. If you have installed the complete Adobe Acrobat suite correctly, you should have an Adobe PDF printer on your system.
Maybe I misunderstood your question. In Acrobat 6 or 7, from the Document menu, select Add Watermark & Background. The resulting dialog allows you to choose either watermark or background, the source PDF file for your background or watermark, the Page rand (all or selected range) vertical and horizontal alignment, rotation and opacity. You can also see a preview of the page in this same dialog.
I find this method to be a lot easier than screwing around with FOSI headers and footers.
