Anyone know the cause(s) of the "Error return '0' from ACL DVI generator" fatal error from the composition engine?
Hi John,
I see you have a case open with TS.
As you may have found out, this error is quite generic, and can be the result of a large number of issues.
Let us know how the case turns out, in case others run into the same issue. Thanks!
