On 4/4/06, Brian Jensen <brian@kik.co.jp> wrote:
Keith,
There is an event called ApplicationClosing that should do what you are
looking for. Documentation for it can be found in the Programmer's Guide
in chapter 12.
Brian Jensen
Kyoshinsha Co. Ltd.
brian@kik.co.jp2-9-5 Morinomiya-chuo Chuo-ku
Osaka 540-0003 Japan
Tel: 81-6-6941-8881
Fax: 81-6-6941-1053
Keith Berard wrote:
> Hi again,
> I'm wondering if there's a specific event (that I can add to
> Application.addEventListener
) that specifically handles when Epic itself is
> quitting.
> I know I can look for window_closed or window_closing, and then, presumably,
> check if there is only one window present, but I'm wondering if there is a
> better, or more direct way.
> I'd like to stick with AOM, and avoid ACL callbacks if at all possible, as our
> codebase is primarily Java.
> Thanks,
> keith
>>> To unsubscribe from the list, send an email to
listmanager@maillist.arbortext.com with the following in the body: unsubscribe
> adepters - For additional information on the adepters list (how to subscribe or
> unsubscribe etc), send an email to:
> following in the body: info Adepters - You may also go to
forums.arbortext.com,
> enter the Adepters folder and change your subscription options and preferences.>>
