Can Arbortext Editor version 5.0B be used on Windows 7? Right now I am using it on XP. Thanks.
While not supported by PTC it *should* work. You might find some dodgy UI elements and so on but the functionality should be there. Worst case, Windows 7 includes a complete virtual machine of Windows XP so you could keep running Arbortext Editor under the virtual XP environment inside of Windows 7 itself.
