Arbortext 5.4 Tag Template Shortcut
ptc-5908692
Does anyone know if there is an existing shortcut/hotkey for Tag Templates in Arbortext 5.4? If not, then is there a way to create custom shortcuts/hotkeys?
The acl command to assign a shortcut to the tag templates is:
menu_change .Tools.Tag_Templates... -key 'shortcut'
where shortcut is some key, like 'control-y'
6 REPLIES 6
rdiaz
(To:ptc-5908692)
Hi Kenneth,
Are you looking for a shortcut to just bring up the tag tamplates dialog box, or something more to insert a specific tag template to the location where your cursor current is?
Hi Rafel,
After I posted my original question, I find out that I can pull up the Tag Template dialog box by seperately selecting - Alt, T, L. It's definitely quicker than clicking Tools, Tag Templates.
Although, do know of any other hot keys that will either bring up the Tag Templates dialog box or insert a specific Tag Template?
Thank you,
Ken
I believe it's possible to do it using the ACL, but it's a complex way and needs a good knowledge about ACL.
rdiaz
(To:ptc-5908692)
Robson is correct. This would likely be enacted by ACL. You can get some good info looking into the term keymap in the Help Center, such as the article:
http://www.ptc.com/cs/help/arbortext_hc/ae60m120_hc/
All,
Thank you for your assistance. I believe adding this shortcut will help my team be more efficent.
Your help is greatly appreciated,
Ken
