Arbortext 6.1 custom application issue when upgraded to ATX 7.0
arupkundu
6-Contributor
We are using arbortext 6.1, we are using custom application containing different schemas and it is referenced from a server....application works fine in arbortext 6.1 but the same same application is not working properly in arbortext 7.0 getting unknown tags and attribute errors saying its not defined in xsd file, which is really strange.
structure of the application is each schema folder is different under doctypes for ex - doctypes->diagonostic, doctypes->description etc so each schema has its own xsd files, schema template and catalog file, dcf file etc.
need help on this asap!
please let me know the root cause of this issue
Awaiting your reply
8 REPLIES 8
At some point they switch from dita 1.2 to 1.3 in 7.0 M60. This made our application not happy. See case
CS263588.
Bryon
arupkundu
6-Contributor
(To:bfriesen)
i dont have access to see the cases, could you please elaborate the issue
The title is Upgrade to 7.0 M060 open document almost everything is out of context Arbortext Styer 7.0 M060
Resolution:
Bryon
arupkundu
6-Contributor
(To:bfriesen)
Information is not clear enough on what to be done and where it has to done to fix the issue, could you please explain the resolution little briefly
We sent our application out to the consultants, and let them make the required changes as I could not figure out what needed to be changed from Dita 1.2 to 1.3.
Bryon
arupkundu
6-Contributor
(To:bfriesen)
can you suggest me any resolution for this?
arupkundu
6-Contributor
(To:bfriesen)
Any changes to be done when 6.1 32 bit customized arbortext application package being used in 64 bit atx 7.0?
Please suggest me what to be done
Other than sends it to a consultant for modification. You could try installing Editor 7.0 M050. It should still use dita 1.2.
Bryon
