I just upgraded to Arbortext 6.0 M010. We use Distiller to generate PDF files. In an ACL I have the set usedistiller = on andset pdfprinter = "Adobe PDF". In Arbortext 5.x when I had the usedistiller option set to "on" the option to select a publishing config file would go away or at least be disabled. In 6.0 it is still an active option. Is there anyway to disable this? I've checked the DCF but haven't had any luck.
Thanks in advance for your help.
Hi Sarah
This sounds like a bug, please open a support case so the product can be updated. Let me know if you need any assistance in opening a case.
Susan
Susan Fort
Product Manager, Arbortext Business Unit, PTC
- | (937) 743-9091
