Just started to get this error when checking out of Windchill via Arbortext:
Pagedesc counter variable "taskcdct" is modified in the styledesc.
This is pmrim, periodic maintenance. How do I find styledesc to fix?
The Print/PDF stylesheet in the Document tab was "(pe) [default]".
How do I find to open this if I need to closed the document, which means check it back into Windchill?
It appears the file is pe.fos. If you can't open it in Arbortext Editor, you can use an ASCII editor.
