Arbortext 8.1.0.0 has released!
plutsky
Arbortext Editor/Styler/Publishing Engine 8.1.0.0 has released!
October 20, 2020
Key Highlights
  • Multimedia support in Styler
  • Publishing Engine Security improvements
  • Graphic Preview pane in the CMS Browser
  • The size and location of the Modify Attributes dialog is maintained across sessions
  • New toolbar for CMS operations
  • Add Insert Markup By Category toolbar icon  (previously was Insert Divisions)
  • Strings in the DITA Resource Manager tree control display more than 30 characters
6 REPLIES 6
The Styler download still shows only version 8.0 as the newest.
Bryon
plutsky
(To:bfriesen)
Sorry about that - 8.1 Styler is available now.
Patti
We are still using Arbortext 7.0 with individual Print Composer licenses. We do not use Publishing Engine or Styler. Is there any compelling reason for us to upgrade to 8.1?
For us it was the addition of the postscript option. The pdf file sizes that the default pdf application creates are huge compared to what distiller does for us.
Bryon
That sounds interesting. Could you give me a short description of how that works. Is it something you set in tools or an option you choose each time you publish to pdf? Also, we use Print Preview quite often. Does it have any effect on that?
It has been added to the publish options. So instead of choosing pdf you choose postscript. Once the ps file complete, we use Adobe distiller to create the pdf. It does not seem to affect the print preview.
Bryon
