I am having issues when a PDF is created, the labeling is incorrect and out of order on table of contents, tables and figures. Please see sample file for example. Has anyone co
Is this the using the ootb stylesheet or have you customized it already?
Bryon
They were actually customized for us by PTC, have not modified it since. Have been using the same stylesheet since 5.3 and is now experiencing issues in 8.2.3.
That is a huge jump. The stylesheet will have been modified by editor when you first opened it to bring it up to speed with the version of software. But there will probably be issues like you are seeing. You will probably need to get PTC or Partner (GSPL, EAC, etc) to take a look at the stylesheet and fix anything that broke during the upgrade. We ran into the same issue.
Bryon
EAC here, happy to review the stylesheet and define a plan for making it work with Arbortext 8.2.3.
Mike (msimon at eacpds.com)
