Hi *,
we want to use the Arbortext ActiveX in an C# App. We can open the xml files, edit and save the changes, but we have some problems with customizing.
Could you say me whether next action are possible:
1) creating of new toolbars?
2) setting the toolbar-buttons to unvisible?
3) drag-n-drop of graphics in the xml-file? The graphics are located in the database tables.
There are any documents (help) for the ActiveX in C#?
Thank you very much!
Paul
PS. Excuse me for my english.:-)
Hello!
Paul B wrote:
...There are any documents (help) for the ActiveX in C#?...
Maybe this will help:
2. http://www.dreamincode.net/forums/topic/38890-activex-with-c%23/
Спасибо, Владимир! ![]()
But we need help for Arbortext, not for ActiveX...![]()
Ciao
Paul
Well, you can also ask about this a PTC's technical support, here: "Log a New Case".
I don't have experience in this are, but your best bet, if you haven't solved this or moved on already, is to join the Adepters mailing list where lots and lots of Arbortext users, admins, and developers hang out 24/7/366 (it is a leap year, you know!). I know there are developers there who have worked with (and I think customized) the ActiveX Editor instance.
Information on joining that list (as well as pointers to lots of other Arbortext resources) can be found here:
http://blog.single-sourcing.com/top-arbortext-resources
Good luck!
Thank you to both of you.
No problem.
