Arbortext Editor 5.2
ptc-883334
Hallo to everyone, I have searched for a while now at Google but found no answer. We use an application which we feed with SGML or XML files. Sometimes when we make mistakes (e.g. we forget a char or a tag is not closed correctly) we get error messages saying something like "error in line 123". Is there a way to show the line numbers in an opened SGML or XML file in Arbortext Editor 5.2 ? (Perhaps something like :set number in the vi Editor ?) At the moment we open up the SGML file in an external editor, check the line, switch back to Arbortext and make the neccesary changes. Thanks a lot for your help.
lfraley
6-Contributor
(To:ptc-883334)
This question was posted to adepters in the past. The answer is here:
http://portal.ptcuser.org/p/fo/st/topic=21&post=79284#p79284
The PTC/User portal (http://www.ptcuser.org) hosts the long-running Adepters mailing list. This list started in 1996 and has always been monitored by the PTC/Arbortext software engineering staff. Many long-time users and tools folks also regularly monitor the list. If you have a question, it's a really good resource as questions generally get answered within 24 hours. Beginning and advanced questions encouraged.
The List Email Address is: -
You can join the list from the PTC/User portal: http://portal.ptcuser.org/p/fo/si/topic=21
