Getting an error in AT Editor 6.1 when trying to print a simple enough XML document.
The error window states "editor.exe: segment violation (signal 11)".
When I pull up the editor_err.log file in my Users\TEMP folder, it reads this:
PTC Arbortext Editor (Build R61M010-339) terminated unexpectedly at Thu Sep 25 14:18:18 2014:
Current ACL statement at "C:\Program Files\PTC\Editor61\packages\main\_winev.acl":71:
71 [1] return
ACL function traceback at time of error:
#1 print::modified_print() at "C:\Program Files\PTC\Editor61\packages\main\_winev.acl":71
Local variables of active function:
$p1=0
$p2=0
$o1=(-1,0,0)
$o2=(-1,0,0)
I have no ideas what could be going on. The XML document I'm trying to print is extremely simple:
<!DOCTYPE OUR CUSTOM DOCYTPE HERE>
<searchList>
<row>
<searchTerm></searchTerm>
<context>printOnly</context>
<description></description>
<highlightStyle><style type="highlight"/></highlightStyle>
</row>
</searchList>
Has anyone seen this error before?
Arbortext considers <row> to be an element used in tables for most dtds.
Is <row> supposed to be part of a table in your dtd?
Many documents require as a minimum the following table structure.
<table>
<title></title>
<tgroup cols="1">
<tbody>
<row><entry></entry></row>
</tbody>
</tgroup>
</table>
Hey Kevin,
Are you still seeing this issue? If you've been able to rule out customizations and print drivers (they do sometimes cause issues), you may want to consider opening a case with Tech Support, as this seems a bit more specific than usual.
<table>
<title></title>
<tgroup cols="1">
<tbody>
</tbody>
</tgroup>
</table>
