Hi Gareth,
Your comment about removing functionality, I just wanted to follow up on that. No functionality was removed, in fact by moving to Flexera for licensing, there is more functionality available to customers (able to monitor usage, license borrowing, more license server capabilities, etc). Because the licensing technology changes, customer may need to make other changes, this is one example. Elan (the 5.4 and prior technology) was not particular on the type of license used in a RDP environment (fixed or floating), however, for the Flex license based products to work in RDP the license must be floating. You and your customer’s entitlements will continue to work, the entitlement will need to be upgraded from a locked license to a floating/concurrent license.
You need to contact your PTC sales contact, they can provide you guidance on how your organization, or your customers can convert their licenses (or I can help).
Please let me know if you have further questions.
Susan
Susan Fort
Product Manager, Arbortext Business Unit, PTC
- | (937) 743-9091
In Reply to Gareth Oakes:
Hi Paul,
Thanks for digging up the old thread. Good to hear others are having similar
experiences.
This is a massive red flag for our customers. Many are used to remoting in
to work on things and this is a showstopper for some people. It doesn't seem
right that PTC would remove functionality from a product "upgrade". That is
typically known as a regression. If you purchased something then you expect
it to keep working, and if you are paying maintenance, remain maintained in
its functional state.
We'll check in to what can be done for our customers. Thanks again for the
response!
Cheers,
Gareth
