Arbortext Editor: How to link a PDF file on it?
ptc-2693819
I just a newbie for using this application, I still couldn't find how to make a link of the other type of documents except its current document and web (URL) into it, such as Microsoft Word, Microsoft Excel, Acrobat Reader files (PDF) or another? I desperate for it. ... thanks for you all.....
7 REPLIES 7
lfraley
6-Contributor
(To:ptc-2693819)
Hello yuliyono! Sounds like you're making progress. I'm not sure what you're asking for here. Are you trying to create a PDF? Are you trying to create a link to a PDF? Into a specific point in a PDF? Are you trying to fold a PDF into a larger PDF? All of these take different strategies to achieve.
Hello Liz,
A search turned this up. I have what may be a similar challenge.
I would like to fold a pdf into pdf created by Arbortext. At a specific point. Ideally I would like to apply some styling elements (such as headers / footers, page numbering etc.)
What strategy would you recommend to do this?
Mark
lfraley
6-Contributor
(To:MarkMitchell)
Are you trying to reformat the PDF you're folding in or just trying to insert an existing PDF between 2 pages?
At first I would like to just insert. Ideally this should be automated during the publishing of the Arbortext document as this needs to be done on a high volume of documents.
Later, perhaps, I would like to do some basic formatting like add headers, footers and page numbering consistent with the document that we fold it into.
Mark
lfraley
6-Contributor
(To:MarkMitchell)
You don't reformat an existing PDF -- that is, you don't take a PDF as input and change it's look inside PDF format. You take the original content and recreate the PDF with the new format.
You can fold in a new PDF by intersecting the publishing pipeline. This may take a bit of ACL code.
As these are legacy pdf's I guess the best I can do is intersect the publishing pipeline.
Thanks for the tips.
Mark
Hey Mark,
Sorry this is a bit late, I don't come onto this forum as much as I should
I had a simlar query quite a while back and got directed to two places:
1. pdfconfig.dtd
2. http://itextpdf.com/
Good luck!
Cheers
Pete
Simonsoft UK Limited
