Arbortext Editor and Arbortext Engine Compartibility
spalani
  Plan to migrate the below  Documentum  Components for
new wisdom 2016 project.
  1. WebTop    -  6.7 SP2   to  6.8  version
  2. Content Server     -  6.7 SP1   to  D7.2 SP2 version
  3. DFS  - 6.7 SP1   to  D7.2 SP2 version
  4. Windows OS      -  2008  to  2012
Can you please check Arbortext Editor and Arbortext Engine  current version (6.0M060 ) or new version (6.1 or if any) Compatibility  with  WebTop and content server  above mention
new version and provide the details on this.
Thanks for helping  on this .
Siva
TimPhelps
(To:spalani)
Documentum 7 is not supported
Documentum 6.8 is supported on Windows 7 and Windows 8
JDK 7 U21 is supported
See http://support.ptc.com/WCMS/files/169431/en/Arbortext-Software-Compatibility-Matrices-6.1M070.pdf
See pages 11-13
14 REPLIES 14
TimPhelps
(To:spalani)
Arbortext Editor 6.0 M140 is compatible with Documentum WDK 6.5, 6.6, 6.7, 6.7 SP1 and 6.7 SP2 with Apache Tomcat
It is compatible on Window 7 and 8, but not with IE10 or higher
Arbortext Editor 6.1 F000 - M070 support Documentum WDK. 6.1 M080 does not.
Be sure to let the community know if this answers your question
Thanks for your response.
I need some more clarifications on this.
What is the latest version of Arbortext Editor and Arbortext Engine ?
If have a latest version then following version can be compatible.please provide the Yes/No and provide the compatible with comment against on below :
1. WebTop    -  6.8  version
2. Content Server     -  D7.2 SP2 version
3. DFS  -    D7.2 SP2 version
4. Windows OS  server    -  windows 2012
and Is Arbortext Editor certified with Java 8 & IE 9+? and Is Arbortext Engine certified with 2008 or 2012?
Our wsidom application currently using version 6.0M060.It can be  compatible with below  version.  please provide the Yes/No and provide the compatible with comment against on below :
Please provide the details on this?
Siva
TimPhelps
(To:spalani)
The latest version of Arbortext Editor is 7.0 M010.
This information is available at the PTC support site.
http://support.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm
and
Compatability info is available at
http://support.ptc.com/WCMS/files/168977/en/Arbortext-Software-Compatibility-Matrices-7.0-M010-11.1-M010.pdf
The 7.0 release of Arbortext Products does not support Documentum.
So "No" is the answer to your questions.
Please to migrate the Arbortext Editor and Arbotext Engine 6.0M060 to 6.1 M070.
Seems like 6.1 M070 compatible with below  version :
1.  Documentum WebTop  -  6.8 version
2.  Documentum Content Server  -   D7.2 SP2 version
3.  Documentum DFS Content Server  -   D7.2 SP2 version
4.  Windows OS  server   - both windows 2008 and 2012
5.  IE -   IE 9+
6. Java -  Java 8 version.
Can you please confirm on this.
TimPhelps
(To:spalani)
See pages 11-13
Hi
Tim Phelps – Quick question, 6.1 M070  will support Documentum 7.2 and Webtop 6.8?
Siva
TimPhelps
(To:spalani)
No, I am sorry to say. Arbortext 6.1 M070 will not support Documentum 7.
As stated in the Software Matrices, it states as of "Feb. 4, 2016:
Initial revision for release 6.1 M080. PTC Arbortext Digital Media Publisher, PTC Dynamic Link Manager,
PTC Arbortext Import/Export, PTC Arbortext Excel Paste, and PTC Arbortext Adapter to
Documentum/WDK are no longer supported."
Currently  Arbortext Editor and Arbortext Engine  version 6.0M060 using  our application.
Plan to migrate new version of Arbortext Editor and Arbortext Engine in our application.
Which new version (higer version of 6.0M060) will support Documentum 7.2 and Webtop 6.8?
Siva
TimPhelps
(To:spalani)
None. It is not supported.
Hi Tim Phelps,
Our project plan to   upgrade Arbortext Editor and Arbortext Engine version 6.0M060 to 6.1  M070.
Please provide the Download link for 6.1 M070 and also installation guideline or any support documents  to upgrade 6.0 M060 to 6.1 M070
Can you please help me on this.
Siva
spalani
(To:spalani)
Any update on this
TimPhelps
(To:spalani)
The link to the down load site is https://support.ptc.com/appserver/cs/software_update/swupdate.jsp
The installation guide and release notes are found in the download.
Hi Tim Phelps,
Our project will have the License for   Arbortext Editor and Arbortext Engine  version 6.0M060 . New migration needs for new license or shall we able to reuse the existing licenses.
Our project needs to perform Custom.zip for validation for the templates.
Please provide the technical contact person details , I need to schedule a call with him and get the all the required details for this migration
Siva
spalani
(To:spalani)
Any update on this
