We have two people working on one document instance. The license is up for renewal for one in March, and the other in November. The one in March more than likely will update to new 8.2.0.0 while the other will still be on 8.1.2.1. Will there be any compatibility issues, or any noticeable differences on publish using Arbortext publisher option?
The stylesheet will need to be updated for 8.2, but otherwise we don't expect any major differences. if the two users are doing local publishing using their own copies of the stylesheets they should be ok.
That said, we can't guarantee there are no minor differences in the output.
Thank you very much.
