Arbortext and Windchill Integration
ManishaPawar
Could anybody help me doing Arbortext and windchill integration using
Object->Connect
I used content manager guide to configure the PTC server. No Success.
Thanks in advance,
Manisha.
Hello Manisha,
You should create file
<arbortext_install_dir>\adapters\com.ptc.prowt.arbortext\siteprefs.xml.
Best way is to create a copy from file "siteprefs_template.xml" is localted
in same dir.
Next you should define Windchill server name. Open siteprefs.xml file, find
element <parametername>HostList</parametername> and his child element
<parametervalue>.
Define server name in format: Name|Windchill connection URL, like in
example below:
<parametervalue>r70|">http://r70.windchill.ru/Windchill</parametervalue>
</parameter>
r70 - what I see in server field,
