I have installed and reinstalled Arbortext 8.2.2.0 several times now chosing the Print Composer option (yes Print Composer is on my license file say for 8.2). However PDF option is not where in the export on the menu...Please help
Okay, I installed Arbortext with styler along with editor and now I have Print Composer options showing up. I do not have a license for styler (just editor and print composer), but its install must awake something in the software as it would not work with installing just the editor and print composer alone. Very annoying issue.
