I just wanted to ask regarding Arbortext layout editor. Is this a standalone software or does it work when you install Arbortext editor? Upon checking the software download tab I only see the Arbortext editor and no Arbortext layout editor.
Thank you.
That's the idea, Stephen
It isn't always possible to 100% automate some layouts. Arbortext Layout Editor gives you the opportunity to format XML content to 95% of your requirements, and then edit the formatting of a page to achieve the final 5%.
Simon
Hi Stephen
Arbortext Layout Editor is unrelated to Arbortext Editor, but closely related to Arbortext Layout Developer. It is a simplified version of Layout Developer, with the 'developer' parts restricted. The intention is to provide a 'document finishing' application for Layout Developer users who only want to make finishing touches to a publication before printing.
I hope this helps
Simon
I see I see. So correct me if Im wrong, after my XML formatting and tags i enter it in layout to fix the format of the page itself?
Simon
Hello @Stephen_DeLeon,
It looks like you have some responses from a PTC Product Manager. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
