Arbortext publishing engine 8.2.3 with axis2 in order to use PEWebService
DD_9798060
3-Newcomer
Hi all! we need to use APE 8.2.3 with PE SOAP but is deprecated from version 8.1
i have integrated axis2 in our apache 9, but something is wrong, i cannot get the pdf, the APE do not generate it and i didn't have any response.
now i am using:
http://MYSERVER:8080/axis2/services/PEWebService
instead before with version 8.0 i am using:
http://MYSERVER:8080/PEaxis2/services/PEWebService
i get the same info, i see the wsdl 🙂 ... what i have done is to copy the PeWebService.aar from the version 8 to the version8.2.3 (i don't know if is correct)
Summarizing... can someone explain me or show a guide in order to have enable the PE SOAP in the version arbortext publishing engine 8.2.3 ...  due my application needs it....
thanks a lot.
david,
Hi @DD_9798060,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
