I'm working with Arobortext Advanced Print publisher Enterprise, but i cannot get any information for what this server can do from the document download on PTC IT Support website. Who can help me, and give me a quickly guide to use this software. And also give me a sample job file, thanks a lot.
OK
APP Server is the same as desktop in most respects, you can use it for pagination or development and running of manual or automated templates.
APP Server allows you to additionally run Formatting to Print opperations 'unattended' so unlimited by pop up dialogues and without the interface, via command line so can be configured as a batch pagination engine in effect.
APP Enterprise and now APE allows you to take this one step further into job queue management, multiple pagination agent, etc etc...
Hello
APP Enterprise is a set of tools that work with APP Server at its core. If you are looking for general information there is a 'help' content that comes installed with APP-E (formerly called ACS or Advent PM).
There is also an old white paper I wrote 'many' years ago which will give you a little more background alternatively we do offer a full 1-2 day training course on APP Enterprise.
For APP-E customers on active maintenance you can now also migrate to Arbortext Publishing Engine should you wish to now APP-E is sunset.
Chris
tformat.com
Thank you, Chris. I made a mistake, i have a Arbortext APP Server license, i thought this used for Enterprise version. Do you know what is the APP Server, what different from APP Server and APP Desktop
OK
Thanks for you help,chire
