Auto filename in PDF-publications (PTC Arbortext Editor 8.2.2.0 with Styler)
LV_9577874
Hi, ptc Community.
I have an XML document in a CMS repository.
Is there a way to set a prefix to the filename of the PDF pubblicated locally by ArborText via File->Publish->PDF?
I have some document attributes, as language and version, that I would like to set automatically to be inserted in the name without changing it manually each time a PDF is published in that way.
Thanks in advance.
Arbortext is very customisable. You could create your own menu items, buttons, or keyboard shortcuts. For example you could have a custom publish button that does the publishing then renames the file automatically. This is achieved with ACL (Arbortext Command Language), which is fully documented in the Arbortext Help Center.
Hi @LV_9577874 ,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
