How to autofit bigger tables in Arbortext. When I render PDFs with bigger tables, I am facing an issue
Hi
I presume you are using Styler Stylesheets rendering through ALD?
DITA/CALS?
Besides adjusting mark-up for variable widths "*" etc ALD has a whole host of features to automatically adjust tables, control overlaps, re-organise columns, rotate and split large tables etc etc... some basic items you can access from the Styler menus table config, some from ALD source edits, ALD functions and some might need custom template add-on work. All depends to what extent you need to cover this.
Chris
//arbortext.solutions
